Problem rotate command
sander.van.pelt
sander.van.pelt
Hello everybody,
Since yesterday my rotate command is not working as it should. I do need to use the "RO" command instead of my "R" command to specify a basepoint first and specify the rotation angle after.
I didn't changed my Acad.pgp file and if I control this, the R command is still visible (R,      *ROTATE).
If I use "aliasedit", first becomes this window visible
But after selecting "OK", I can add a "New Command Alias". If I add alias R is the Rotate command, you'll see this alias twice in the acad.pgp file after saving.
And still I can't rotate objects by selecting a basepoint first, and specify a rotation angle after.
If I check my last added lisps, there is nothing what could cause this problem (if I am right). And after unloading these last added lisps and restarting AutoCad, the problem is still not solved.
Does anyone know what could be causing this/how to fix it?
ВeekeeCZ
Use (findfile "acad.pgp") to locate your current pgp file and post the file here to take a look at the syntax.
ВeekeeCZ
@sander.van.pelt wrote:
... I do need to use the "RO" command instead of my "R" command to specify a basepoint first and specify the rotation angle after.
I didn't changed my Acad.pgp file and if I control this, the R command is still visible (R,      *ROTATE)....
How did you do this? Did you or did not?
sander.van.pelt
I opened the acad.pgp with notepad to check it. "Control" may not have been the right choice of words (English is not my main language).
I have attached my acad.pgp (as .txt) to this reply.
The R=rotate command is already visible under the "R" commands, but also at the very bottom after adding this via "Aliasedit"
ВeekeeCZ
-PAN, *-PAN
Here is your syntax error.
But I could load pgp anyway. However, ALIASEDIT did not handle it.
Also, I wouldn't try to prove the algorithms by this line... however it looks like he can handle it.
