Hello again,
I've been using autocad since 2015 and I've also used Revit since 2015.
I prefer to have a white model space background rather than the default black.
It is cleaner and way clearer.
Can autodesk please make the default background in Autocad white instead of black?
Hello again,
Solved by pendean. Go to Solution.
Solved by Tomislav.Golubovic. Go to Solution.
Solved by ВeekeeCZ. Go to Solution.
If you mean manually (OPTIONS>COLOURS>BACKGROUND) then yes I do know that. Why must model space be black by default?
I included Revit in the preamble as an example by the way.
It's not so long that they have changed the UI color to even darker. They made some research and found that it's better for our eyes... so. Better set the background to white yourself because they're heading in the opposite direction.
