Attribute Block insertion error
When I try to insert Attribute Blocks into the drawing area, the blocks are exploded as shown in the screenshot and does not work properly.  Would anyone be able to help me to solve the issue?attribute block.jpg
imadHabash
I suggest to check the Explode option from Insert dialog is not selected . If not fixed .. please post here a CAD dwg sample for testing ?
Imad Habash
dbroad
What is GRIPBLOCK set to?  If 1, set it to 0.
Architect, Registered NC, VA, SC, & GA.
pendean
Community Legend
Community Legend
How are you "inserting" those blocks exactly?
Thank you for your reply.
Your suggestion solved the problem!
Thank you again for your help!
