I have an upper mid tier pc and graphics card that I recently built (rtx 2060 gpu and a ryzen 3800x cpu) but whenever I try to trim a curved line or do some simple commands, things like attempting to place a polyline in certain areas AutoCAD freezes and stutters it's killing my productivity and it's really frustrating. I have the latest version of 2022 and the latest Nvidia drivers.
Thanks for the reply, I had already downloaded today's latest update, copying the geometry to new files, recovering, auditing and purging to no avail. I tried your suggestions, and while it managed to alleviate some of the delay, it began to stutter and it still managed to slow down to the point of freezing entirely, forcing me to end task. Even turning off hardware acceleration. I'm really considering testing if a previous autocad version will work, but I don't really have that type of time so I may just do my plans in rhino, and clean them up in Revit idk.
And small correction I actually have an rtx 2070 gpu, I said 2060 by accident.
In your last drawing with column grid you have used a lot of unnecessary splines elements even for straight lines !!! this is weird and not recommended . i'm also found some lagging especially when my mouse come over that drawing . I suggest to replace all that unnecessary splines with lines or polylines that will solve your issue . 🙂
Imad Habash
Appreciate the sugguestion but even after converting splines to polylines the problem persists. I'm currently frozen as we speak.
Other than RECOVER command finding 19-errors in your file, I see no slowdowns here.
See attached and a WBL:OCK test file for your use.
interesting when I used recover it only reported one error before I uploaded it...I can't really be sure what the problem is but I appreciate the help so far. It's really odd because I've ran grasshopper scripts on rhino 10x heavier and this has happened on my laptop before too.
