Hello, I believe from the "latest release" info that syncing with OneDrive/Dropbox etc just got better? I understand that to mean that you don't have to rely on 360 anymore. What I am having a problem with is 'Drawing History' or 'Drawing Version History'. Can anybody suggest why when I go to View / Drawing History I get the following message:
Many thanks, apologies if I've missed anything I am a new poster.
Solved by mikefadsk. Go to Solution.
YHi,
I miss an information from you:
You followed both links? and you are logged in OneDrive?, or why do you ask here about this information?
Sebastian
Hi, Paul. The "sync" of OneDrive/DropBox/Box has not changed and is still controlled by the sync client from those apps. This new Drawing History palette does add the new functionality of displaying any previous versions that those 3rd party storage providers may have already stored for the DWG you opened.
To use the feature you must be on a subscription and your account has to have the "DWG History" entitlement enabled for you. If you have a CAD manager, it may be that they have not yet assigned that entitlement for your login. Once you have the entitlement, it will appear in your account as "AutoCAD - DWG History" like my screenshot, attached.
Mike
AutoCAD Test Development
Autodesk, Inc.
Hi Mike, That is very helpful thank you. I guess I am the CAD Manager, we are quite a small user, 1 Product Design+, 3 ACAD seats and 2 LT. We are on Subscription but my list has 'Drive' and not 'Autocad - DWG History', is it an additional subscription or does our Reseller need to just enable it?
Hi, Paul. I think the "DWG History" entitlement should be part of regular subscription. I'm going to request someone in the product support team to reach out to you to help figure out why you are not seeing it.
Mike
Hi Mike, This may be a wider spread issue. I am also on subscription (single LT seat) and it doesn't show up for me either. For reference, I have had the same single seat licence for several years, so I have rolled through the various purchase models (maintenance etc).
I have not a regular subscription, but it should act like them,
i can see it in my cep.
Not an answer, just an information that other users have access.
I am a german (version) user.
Sebastian
