Autocad 2021 has changed the way dynamic input works, and I can't figure out how to use it the way I used to:
Screencasts are attached for a visual explanation.
Does anyone know how to change dynamic input back to how it previously worked? Or know how to do the above commands correctly so they work with the new version of dynamic input?
Yes, happening in all files. I've upgraded from Autocad 2020.
Osnaps are running all my usual settings - first column fully ticked, plus extension, insertion, tangent.
Just to clarify, these problems only happen with tracking from the second point of a rectangle, not the first point.
The first point of a rectangle I can track off a set point by any measurement I want, and it is accurate in distance and alignment from the original point.
