I have weird pdf plotting issue with new 2020 AutoCAD, I can't plot A1 size in landscape mode for some reason, it's working on A3 size but not A1, it worked perfectly in 2019 version, all plotting setting were transferred to new AutoCAD version, I tried a few different pdf plotters including AutoCAD dedicated one. can someone please help. Thank you!
also tried to reinstall all the plotters etc, created a new setting for plotter, all options for landscape are selected right, and as you can see on ex1.pdf, the paper itself is in a landscape but the drawing plotting in portrait, when previewing plot it is showing in the landscape. settings attached worked on 2019 version.
Was this issue solved? I have the exact same problem with landscape selected everywhere and the little paper image still showing portrait.
I copied over a pc3 file that worked in 2019 after the problem appeared to see if this would fix the issue somehow, but no luck!
Unfortunately it's not solved yer if you usd 3rd party app, it's only work with default autocadd dwg to pdf converter when selecting landscape paper by dimension. I have to go back to 19 version because of this issue, sadly.
This worked for me:
Plot -> Preview (PDF) -> Print -> PDF -> Save as PDF . . . . open in Preview and print
Not for me...it's still exactly the same!
I installed the update after restarting my computer; re-created an A1 PDF using the PDF option (not a previously configured A1) and it still does the same thing!
I just installed Autocad 2020 last week and I am having the same problem. There are two different Adobe PC3 files I use to print and no matter what orientation you select it prints it out the opposite way and cuts off half the drawing. Need to get this fixed ASAP!!!!
Try the setting as per the picture attached.
I'm using CutePDF wich works form me you could try it also and it's free.
I’m very rusty in auto cad now back to it again after 15 years. I’m using LT2020 for Mac. It print out thick too example dim line. When I checked the layer it’s dim layer. I’m not sure what to do or any standard setting I can upload? It views in pdf acrobat. Thanks so much
