AutoCad 2020 External Reference Palette is Missing Transparency
joehovarter
Message 1 of 31
joehovarter
AutoCad 2020 External Reference Palette is Missing Transparency option. This was available in 2019 and seems to be missing or am I missing something?
I have always accessed by right clicking on the palette window bar and selecting transparency is there another method? Layers Palette, new blocks palette and properties all are still available.
Replies (30)
Message 2 of 31
S.Faris
It is available in mine. Make sure PALETTEOPAQUE is set to 0.
Or try Resetting the CUI if that is OK with you : How to reset the CUIx in AutoCAD
SALMANUL FARIS
Message 3 of 31
Alfred.NESWADBA
Here you find a screenshot with external reference palette, on the left side 2020, on the right side 2019 ... where do I miss the difference? And where do you see a transparency setting in 2019?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 31
joehovarter
Here is a pic of mine missing. Weird because other palettes transparency is available. Acad 2019-04-04 101814.jpg
Message 5 of 31
joehovarter
PALETTEOPAQUE is set to 0 and I reset cui to installed state with no change.
I usually don't migrate settings when installing, in this case I did.
Message 6 of 31
S.Faris
If you don't mind resetting Autocad, Here it is : How to reset AutoCAD to defaults
SALMANUL FARIS
Message 7 of 31
Alfred.NESWADBA
Thank you for clarifying this!
And sorry to say, I don't have that (right click) option "transparency" in 2020, but I also don't have it in 2019.1.2.
And I can confirm, that e.g. the layer manager palette shows this option.
But I have no idea how to get it transparent.
Sorry, - alfred -
Alfred NESWADBA
Message 8 of 31
pendean
Community Legend
Community Legend
I too do not have it in R2020 nor R2019.1.2 versions of AutoCAD: looks like it got taken away an update or two ago in R2019.
Message 9 of 31
S.Faris
In my case its available on both 2020 & 2019.1.2
SALMANUL FARIS
Message 10 of 31
Alfred.NESWADBA
Are you on Windows 7 or 10
Are you on a monitor with 1920x1080 or higher?
- alfred -
Alfred NESWADBA
Message 11 of 31
S.Faris
I'm on Windows 10, with a 1920 x 1080 Resolution
SALMANUL FARIS
Message 12 of 31
Alfred.NESWADBA
I'm on Windows 10 (1803) with a resolution higher than 1920x1080 (2560x1440)
@pendean how's your setting?
- alfred -
Alfred NESWADBA
Message 13 of 31
pendean
Community Legend
Community Legend
@Alfred.NESWADBA Windows 10 (1803) with a resolution of 1920x1080
Message 14 of 31
Alfred.NESWADBA
@pendean thx!
@S.Faris is your Windows 10 also supplied with update 1803?
But all sounds quite similar, so I have not really an idea why we have so different results.
- alfred -
Alfred NESWADBA
Message 15 of 31
S.Faris
Just incase if it helps
I'm on a clean install and not using any migrated settings from previous versions, on both 2020 and 2019.1.2.
SALMANUL FARIS
Message 16 of 31
S.Faris
I'm on 1809
SALMANUL FARIS
Message 17 of 31
Alfred.NESWADBA
>> I'm on 1809
@S.Faris well, that is something different now
@joehovarter can you show your Windows version?
- alfred -
Alfred NESWADBA
Message 18 of 31
joehovarter
Windows 10 1809
Its the same in 2019.1.2, no option available. I was running a different workspace recently and didn't notice it. Pretty sure it was available in original 2019.
So am I able to set it transparent some other place? By command?
Message 19 of 31
Alfred.NESWADBA
Well, as far as I can see @S.Faris is the only one having this option available, no one else has it.
And we all have mixed environments, Windows 10 1803 and 1809, Resolution of some Full HD, some > Full HD, ...
I can't see now anything to make this easy to identify.
No, not by command, I guess registry is the only position you might be able to find this.
- alfred -
Alfred NESWADBA
Message 20 of 31
pendean
Community Legend
Community Legend
Cranked up R2017 to check, it appears you remember something else somewhere else most likely
