Working with ACAD 2019, it has a delay of around 500ms following every click and keystroke. This is making the software very difficult to use. For example, when selecting with a fence, if I make the second click too quickly ACAD doesn't register it. I have checked that this also happens in the provided sample files, so it's a software or system issue, not a file issue.
Solved by john.vellek. Go to Solution.
HI @Anonymous,
Have you applied the updates for AutoCAD 2019 using either your Autodesk Desktop App or from your account page?
HI @Anonymous,
I got a new computer about a week and a half ago, and I've been using Revit since then, so this is my first time using ACAD on this machine.
OS: Windows 10 Pro (build 1803)
CPU: Intel i7-8700K
GPU: AMD Radeon Pro WX 7100
Mouse: Corsair Scimitar RGB, Firmware v. 2.04 (latest)
Keyboard: Corsair K95 RGB, Firmware v. 2.05 (latest)
Yes, the problem persists in a new blank file.
Files are stored on a local server.
Haven't tried disconnecting from network, but I will do that after hours today.
CPU: Intel i7-8700K
Hi @Anonymous,
Do you have any add-ins running with AutoCAD? Do you have any shared resources on your network such as fonts or pc3 files? If so, try logging on as a new user and work with Out-of-the-box AutoCAD on your C: drive to see if it behaves.
Hi @Anonymous,
Not running any addins.
Signing out solved the problem, thanks!
Now you know I have to ask... why did that work?
