Hey
We had to do a reinstall of my PC and since then, the fonds in all my drawings are to big and jagged. The files are fine, there is a problem with AutoCAD since the reinstall.
I use ARIAL (but it does not display as Arial), I made most of the drawing myself (and all the affected text), I never before had any problems with it nor do my coworkers, I had AutoCAD 2019 before and it worked fine and it still works fine in the TrueView, I have the latest drivers for my Nvidia FX3800, the latest AutoCAD update, I tried turning on and off Hardware Acceleration and smooth lines, there are no Annotations active...
I don't see what changed sinds the reinstall, but the text renders different and wrong.
I attached a screenshot of a part of the drawing. The .dwg is on the right and the same part of the .pdf (I made from the file a couple of days ago) on the left
john.vellek has embedded your image(s) for clarity
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
Can you share your drawing file with me? If you have assigned ARIAL but it is not displaying as such, then AutoCAD cannot find it or it is damaged. In this case, a different font (Simplex is the default) is used. This font can be changed using Fontalt.
When you indicate that you are using Arial, is that also the Style name or just the name of the font assigned to your current style?
Hi John
It is indeed a style named "Arial" that uses "Arial Narrow" as font, which was not installed.
I installed the font Arial Narrow and it works fine !
Thanks for the help and the quick respons !
