My ribbons for hatch, array, etc., aren't appearing. When I change the HPDLGMODE, the dialog box appears but still no ribbons.
Also, the options that appear right after typing in a command, example: RECTANG Specify first corner point or [Chamfer Elevation Fillet Thickness Width]:, does not appear until the first option is made.
I constantly receive messages like below, when typing in commands.
"Command: System.BadImageFormatException: Could not load file or assembly '36352 bytes loaded from AcWindows, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format.
File name: '36352 bytes loaded from AcWindows, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null' ---> System.BadImageFormatException: Bad IL format.
at System.Reflection.RuntimeAssembly.nLoadImage(Byte[] rawAssembly, Byte[] rawSymbolStore, Evidence evidence, StackCrawlMark& stackMark, Boolean fIntrospection, SecurityContextSource securityContextSource)
at System.Reflection.Assembly.Load(Byte[] rawAssembly)
at Autodesk.AutoCAD.Ribbon.TabEvaluatorFactory.Load()
at Autodesk.AutoCAD.Internal.Windows.RibbonContent.get_ContextualTabEvaluator()"
since when need more details for your issue. let's try:
Good Luck..
Imad Habash
Here's the v2019 version of the same problem on Windows 10 Enterprise 1803 build 17134.523, .NET 4.7.2 (release 461808) ...
Command: System.BadImageFormatException: Could not load file or assembly '36864 bytes loaded from AcWindows, Version=23.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format. File name: '36864 bytes loaded from AcWindows, Version=23.0.0.0, Culture=neutral, PublicKeyToken=null' ---> System.BadImageFormatException: Bad IL format. at System.Reflection.RuntimeAssembly.nLoadImage(Byte[] rawAssembly, Byte[] rawSymbolStore, Evidence evidence, StackCrawlMark& stackMark, Boolean fIntrospection, Boolean fSkipIntegrityCheck, SecurityContextSource securityContextSource) at System.Reflection.Assembly.Load(Byte[] rawAssembly) at Autodesk.AutoCAD.Ribbon.TabEvaluatorFactory.Load() at Autodesk.AutoCAD.Internal.Windows.RibbonContent.get_ContextualTabEvaluator()
It seems to coincide with an error in InfoCenter.log ...
21/02/2019 2:53:01 PM: Configuration Read from: C:\Users\...me...\AppData\Local\Autodesk\AutoCAD 2019\R23.0\enu\Support\infocenter.xml 21/02/2019 2:53:03 PM: ICommunicationCenterConnector.SubAwareServiceUrl does not contain valid URL. Attempting to load from registry 21/02/2019 2:53:03 PM: System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {CEE92F99-D9C7-4E46-9AB7-E3F705B9A543} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)). at Autodesk.Private.InfoCenter.CommunicationCenter.InitCommCenter() 21/02/2019 2:53:03 PM: Error executing network check 21/02/2019 2:53:03 PM: Retrieving the COM class factory for component with CLSID {9E928A7C-095E-4F44-81C5-D4F14F4F0265} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)). 21/02/2019 2:53:03 PM: Error executing network check 21/02/2019 2:53:03 PM: Retrieving the COM class factory for component with CLSID {9E928A7C-095E-4F44-81C5-D4F14F4F0265} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
I ran the Repair / re-install etc. Disabled the error reporting as per https://forums.autodesk.com/t5/autocad-map-3d-forum/what-is-info-center-bad-url-in-xml-file/m-p/8233... Installing the latest updates didn't make a difference.
It seems to be there from the initial (very recent) install, looking at the commandline logs at %LocalAppData%\Autodesk\AutoCAD 2019\R23.0\enu
I googled the GUID from the nfoCenter.log but didn't get anything useful.
Anyone got any tips?
MY fix was to reset the installation as per https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to... and start again. I could import the exported Profile from the old computer so all was not lost. I think it was probably something stray that came across when I migrated my settings from an older installation on another computer.
