AutoCAD Forum
Autocad 2018: Missing Ribbons & Options on command
4 REPLIES 4
1630 Views, 4 Replies
My ribbons for hatch, array, etc., aren't appearing. When I change the HPDLGMODE, the dialog box appears but still no ribbons.
Also, the options that appear right after typing in a command, example: RECTANG Specify first corner point or [Chamfer Elevation Fillet Thickness Width]:, does not appear until the first option is made.
I constantly receive messages like below, when typing in commands.
"Command: System.BadImageFormatException: Could not load file or assembly '36352 bytes loaded from AcWindows, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format.
File name: '36352 bytes loaded from AcWindows, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null' ---> System.BadImageFormatException: Bad IL format.
at System.Reflection.RuntimeAssembly.nLoadImage(Byte[] rawAssembly, Byte[] rawSymbolStore, Evidence evidence, StackCrawlMark& stackMark, Boolean fIntrospection, SecurityContextSource securityContextSource)
at System.Reflection.Assembly.Load(Byte[] rawAssembly)
at Autodesk.AutoCAD.Ribbon.TabEvaluatorFactory.Load()
at Autodesk.AutoCAD.Internal.Windows.RibbonContent.get_ContextualTabEvaluator()"
4 REPLIES 4
imadHabash
since when need more details for your issue. let's try:
  • HPDLGMODE = 2 .
  • type Hatch... to notice Hatch Creation appeared and of course with active Ribbon status. see below image
Good Luck..
Imad Habash
pendean
Repair reinstall R2018 then update it with the latest patch: resist using any migration tools when you start it afterwards and see if your problems go away.
CADbloke
Here's the v2019 version of the same problem on Windows 10 Enterprise 1803 build 17134.523, .NET 4.7.2 (release 461808) ...
Command: System.BadImageFormatException: Could not load file or assembly '36864 bytes loaded from AcWindows, Version=23.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format.
File name: '36864 bytes loaded from AcWindows, Version=23.0.0.0, Culture=neutral, PublicKeyToken=null' ---> System.BadImageFormatException: Bad IL format.
   at System.Reflection.RuntimeAssembly.nLoadImage(Byte[] rawAssembly, Byte[] rawSymbolStore, Evidence evidence, StackCrawlMark& stackMark, Boolean fIntrospection, Boolean fSkipIntegrityCheck, SecurityContextSource securityContextSource)
It seems to coincide with an error in InfoCenter.log ...
21/02/2019 2:53:01 PM: Configuration Read from: C:\Users\...me...\AppData\Local\Autodesk\AutoCAD 2019\R23.0\enu\Support\infocenter.xml
21/02/2019 2:53:03 PM: ICommunicationCenterConnector.SubAwareServiceUrl does not contain valid URL.
 Attempting to load from registry
21/02/2019 2:53:03 PM: System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {CEE92F99-D9C7-4E46-9AB7-E3F705B9A543} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
   at Autodesk.Private.InfoCenter.CommunicationCenter.InitCommCenter()
21/02/2019 2:53:03 PM: Error executing network check
21/02/2019 2:53:03 PM: Retrieving the COM class factory for component with CLSID {9E928A7C-095E-4F44-81C5-D4F14F4F0265} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
I ran the Repair / re-install etc. Disabled the error reporting as per https://forums.autodesk.com/t5/autocad-map-3d-forum/what-is-info-center-bad-url-in-xml-file/m-p/8233... Installing the latest updates didn't make a difference.
It seems to be there from the initial (very recent) install, looking at the commandline logs at %LocalAppData%\Autodesk\AutoCAD 2019\R23.0\enu
I googled the GUID from the nfoCenter.log but didn't get anything useful.
Anyone got any tips?
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
CADbloke
in reply to: CADbloke
MY fix was to reset the installation as per https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to... and start again. I could import the exported Profile from the old computer so all was not lost. I think it was probably something stray that came across when I migrated my settings from an older installation on another computer.
AutoCAD Inside the Factory
