AutoCAD Forum
AutoCAD 2018 Find and Replace problem
5 REPLIES 5
Peter.deVries
1888 Views, 5 Replies
Hello everyone,
For the past few weeks I had been puzzeling with what seemed to be a different way of working of the Find-command.
The problem that I faced, was that I wanted to search for a specific string within the text in my drawing, but AutoCAD would prompt me with "0 matches found". This is a screenshot of my issue: the text 'Rotation' is in Modelspace, while I am executing the Find-command in Paperspace (note that I have the system look in 'Entire drawing'):
What is happening here? Searching the internet, also resulted in '0 matches found' ... strange ... is this a bug?
But today I got a light bulb moment!
It turned out that the 'ANNOALLVISIBLE' was off!!! It seems that AutoCAD only searches the annotative objects that have the same annotation scale as the current when executing the Find-command - or something like that.
Anyway, to find and replace texts, be sure to have the 'ANNOALLVISIBLE' set to 1. Afterwards you can restore the annotation visibility as you would like, of course.
Hope you benefit from this tip 🙂
Kind regards,
Peter
5 REPLIES 5
imadHabash
in reply to: Peter.deVries
i just remind to check the search options settings (if you did not) from the pull down menu (see below image) .
regards,
Imad Habash
Peter.deVries
in reply to: imadHabash
Thank you Imad,
The advanced options haven't been missed by me.
An extra checkbox with 'Ignore annotation scale' or something like that might be useful 🙂 Even if it's just for a reminder.
Perhaps for the next release?
Kind regards,
Peter
imadHabash
would you please attache here your CAD file or part of it to try what you're asking for ?
Imad Habash
Peter.deVries
Dear Imad,
Please find the drawing as attachment for you to see what I mean.
In short, I do not have a problem (anymore), since I found the solution myself. That's why I am posting this, to help others 🙂
Below are two images, which show the different behaviour of the Find And Replace command when the variable ANNOALLVISIBLE is set to 0 or 1. First when the variable is set to 0. You will see that 0 matches were found:
And when the ANNOALLVISIBLE is set to 1? Voilà, 5 matches found !
Do you see what I mean?
Kind regards,
Peter
sbutler502
Wow, very non obvious feature.
Fixed my problem.
Thank you for lighting the way.
Forma Design Contest
AutoCAD Beta
