[AutoCAD 2018] Converting noncoplanar 3D polyline into a solid?
I'm attempting to turn a 3D polyline that's non-coplanar into a solid - all attempts thus far simply result in a surface tracing the boundary. I've tried everything from LOFT to SURFSCULPT and CONVTOSURF / CONVTOSOLID, I've made sure all polylines are properly exploded and jointed via PEDIT, etc.
For me, the shape is that of a leaf that's 'fluttering' in the Z-axis, so it's got some curvature to it in all of X/Y/Z; achieved via splining.
I've attached my .DWG here; if anyone can assist, that'd be much appreciated!
WarrenGeissler
Use Surface - Loft BEFORE you join the splines. Use THICKEN to turn it into a solid.
And if you are going to use this in a large tree model for rendering I hope you have TONS of RAM because you'll blow up your computer.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
tramber
Easy with two 2D views (top and side) that you extrude so that they INTERFERE.
Got it ?
I would have help you more on your file if it was not recorded in 2018 format, that I can't open Smiley Wink
tramber
tramber
This last one is the one you need but you miss two surfaces : top and bottom
But you need "continuity" not sure 3Dpolys are ok
Why didn't you use a spline ?
This solved my issue - thanks very much!
Additionally, this is not going to be rendering lots of leaves for a tree, no - I'm attempting to 3D print these, but needed an actual STL model to slice. Much thanks!
WarrenGeissler
___________________________________________________________________________________________________________________
Oh thank heavens. I showed one of our Revit guys this and he almost fainted! Smiley Very Happy
Warren Geissler
