AutoCAD 2018 continuously lags
braicodavid
braicodavid
I can't seem to escape having lag problems with CAD.
My PC system spec is fully sufficient and is less than a year old.
I'm using AutoCAD 2018. I use a fairly clean workspace in CAD and make sure to purge and delete things.
I have turned features off like 3D cube, selection preview etc.
I have my emails open and maybe a webpage when I'm drawing so I don' know what's causing the lag.
Any help is much appreciated. this is very frustrating.
-David
@braicodavid
Topic Title has been changed by @Tiana_Y for better findability. Original: Laggy CAD
vinodkl
Check if you have updated the AutoCAD to the latest version and turned "ON" the "3DCONFIG" and your dynamic input is turned "OFF".
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ennujozlagam
you can try to switch off your hardware acceleration from options and install latest updates from autodesk and see if helps. thanks
imadHabash
is this lagging happened while opening a certain CAD dwg file or in general ? explain please what kind of lagging ?
there is multi reasons for your issue !! you may need just to turn OFF your snapmode [ F9 ] .
Imad Habash
RobDraw
Is the lag constant and consistent in every drawing?
Rob
pendean
Community Legend
Community Legend
R2018 is not new: so what changed to make it lag all of a sudden?
Or have you been suffering for a year with that new computer?
