Autocad 2017 requesed service not available
It shows up the message suddenly, I can't log in my account. I've checked the  solution link below, still not working.
Link: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Alfred.NESWADBA
What is "it" ... do you mean AutoCAD 2017 or AutoCAD 360?
Because AutoCAD 2017 should be able to work without a connection to A360.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
it refers to the Autodesk desktop A360
pendean
Community Legend
Community Legend
Do you actively use A360?
Do you need to restart your computer?
Can you log-in in a webbrowser? Try it, here is the link https://a360.autodesk.com/drive/app/root
No, just normal usage. Restart is not working.
I can log in the link you that mentioned. A360 shows this message: " unable to connect proxy server..."
Alfred.NESWADBA
That message is new, but quite good as information. "Unable to connect to proxy server" means that your system/the app can't connect to your proxy server, so I guess take your network admin and go through the network configuration. Either the proxy blocks something or your local workstation can't connect/is blocked with some ports needed.
- alfred -
Alfred NESWADBA
pendean
Community Legend
Community Legend
As noted by others, "proxy server" is a problem on your end with your office network. Talk to your IT specialist.
