Autocad 2017 requesed service not available
No aplicable
It shows up the message suddenly, I can't log in my account. I've checked the  solution link below, still not working.
Link: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
0 Me gusta
Responder
494 Vistas
6 Respuestas
Respuestas (6)
Alfred.NESWADBA
What is "it" ... do you mean AutoCAD 2017 or AutoCAD 360?
Because AutoCAD 2017 should be able to work without a connection to A360.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
No aplicable
it refers to the Autodesk desktop A360
0 Me gusta
pendean
Community Legend
Community Legend
Do you actively use A360?
Do you need to restart your computer?
Can you log-in in a webbrowser? Try it, here is the link https://a360.autodesk.com/drive/app/root
0 Me gusta
No aplicable
No, just normal usage. Restart is not working.
I can log in the link you that mentioned. A360 shows this message: " unable to connect proxy server..."
0 Me gusta
Alfred.NESWADBA
That message is new, but quite good as information. "Unable to connect to proxy server" means that your system/the app can't connect to your proxy server, so I guess take your network admin and go through the network configuration. Either the proxy blocks something or your local workstation can't connect/is blocked with some ports needed.
- alfred -
Alfred NESWADBA
0 Me gusta
pendean
Community Legend
Community Legend
As noted by others, "proxy server" is a problem on your end with your office network. Talk to your IT specialist.
0 Me gusta
