AutoCAD Forum
AutoCAD 2017 loading dwg files problem
3 REPLIES 3
316 Views, 3 Replies
I am having an issue whereby Autocad 2017 is open on the home screen - I cannot open numerous .dwg files whereas colleagues are able to?
The file tries to load but then closes and then takes me back to the home screen.Smiley Frustrated
Any help would be greatly appreciated.
3 REPLIES 3
Darin.Green
Chang the variable SDI to equal 0
If this information was helpful, please consider using the Accept Solution
rendermaster
Is it happen to a particular dwg file or to all of your files? Maybe the file needs to recover.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
john.vellek
Hi @Anonymous
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Is it possible to attach one of these files for me to examine? It sounds like the drawing needs some maintenance steps such as Purge, -purge>regapps, and audit.
John Vellek
AutoCAD Inside the Factory
