AutoCAD 2017 Layer Properties Filter
Karol_Piroska
Advisor Advisor
Karol_Piroska
Hi, has anyone issue with the Layer properties filter in Autocad 2017?
The property box is not visible so one cannot apply any filter. You can type in the name (without seeing the box) and the filter appears but you cannot open the filter itself.
rkmcswain
It's working fine here.  It sounds like the Layer Filter Properties dialog is just "off your screen".
It's pretty easy to get back, follow the steps here.
R.K. McSwain     | CADpanacea | on twitter
Alfred.NESWADBA
my guess would be the dialog is eihter off-screen or behind any of the existing windows.
Try:
  • <ALT><SPACE> ==> a context menu should appear
  • use cursor keys <DOWN> until the option "Move" is selected
  • press <ENTER>
  • use cursor keys <LEFT> or <RIGHT> until the layer property window is visible, then you can use the mouse to posiition the window with a <MouseLeftClick>
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Karol_Piroska
Thanks guys, that worked! It was waaaay off somehow. Now when I reopened Autocad it is where you'd expect it to be.
good job 😉
