AutoCAD Forum
AutoCAD 2017 layer dialogue box, compacted unable to read
6 REPLIES 6
689 Views, 6 Replies
AutoCAD 2017 - when I select Layer Properties - the Layer Dialogue Box comes up, but I can not see the details correctly in the box (see attachment).  I have tried increasing the size of the dialogue box but the details in the box remain the same, compacted on top of each other. Sarah
6 REPLIES 6
chriscowgill7373
The columns in the layers palette are similar to those in excel.  if you hover your mouse over the line between header columns it will switch to a double arrow and you can click and expand the columns.  option b: use the command CLASSICLAYER
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
in reply to: chriscowgill7373
Hello
Thankyou for your reply. I have tried expanding the columns, but part of the dialogue box is still overlapping. I have just noticed the same problem has come up in the Layer Settings Dialogue Box, it is also overlapping (see attached pic).
I'm working on Surface Pro 4, thinking it may be a computer graphics glitch?
Sarah
chriscowgill7373
Make sure you have update 2017.1.1 installed for hi-res monitor support.  this may still not solve it as I have noticed not all dialogs have been fixed with the update.  it has something to do with high res and using text scaling in windows
I did an update 2017.1.1 installed for hi-res monitor support, and it worked perfectly!! everything is back to normal.
Thankyou so much for your help!!
Sarah
chriscowgill7373
not a problem.  and welcome to the Forums
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
@chriscowgill7373 is correct that you can drag the column widths to make certain ones easier to see. I suggest that you also explore a rt-click on the columns bar. You can turn on/off columns and my favorite is that you can use the Optimize All Columns.
I hope this helps.
John Vellek
AutoCAD Inside the Factory
