autocad 2016 - weird text issue
tsdrafting
Message 1 of 13
tsdrafting
I am getting this issue more and more. I will be working on a drawing, and when I open a new existing drawing, all my text that is not "standard" get's a squished look (see attached).  I circled in yellow the  normal "before and after".
IF I zoom on my squished text, it is non-legible.  I have to close Autocad completely and restart it to have the text go back, as a regen does not work.  Anyone else out there having similar issues??
Replies (12)
Message 2 of 13
john.vellek
Hi @tsdrafting,
Is this happening with all text or just a specific font?  Do you think this might be related to hardware acceleration? It might be worth checking in GRAPHICSCONFIG.
Please eTransmit a sample file and attach it to a post so I can take a look.
John Vellek
Message 3 of 13
pendean
Community Legend
Community Legend
You probably need to set this to something other than 1:1, like in the "good" drawing
Message 4 of 13
tsdrafting
John,
This happens to random files - and always a specific text.  I have attached an image of my "bold" text that this affects.  Also attached is a copy/paste of my graphics config.  I can post the file if you want, but it is random files, not any specific one, so i am not sure if it is font specific, or hardware specific.  If you want a file, let me know and I can email you my default file I use for all my drawings.
Tony Sterba
Message 5 of 13
Mark_C_123
When it happens, just to be clear - it only happens to that specific arch font that you use. And all the other text/fonts are fine?
Message 6 of 13
john.vellek
Hi Tony,
Did you check to see if the text style is annotative? If so, as @pendean suggests, perhaps you need to assign another scale to it.
If this is not the case, please send me a file with the problem in it so I can look.
John Vellek
Message 7 of 13
tsdrafting
I just did a properties on my bolder text - and it is NOT annotative.  The next time this happens, I will switch that function to "yes" and see if it makes a difference.
Thanks for pointing that out.
Tony S.
Message 8 of 13
tsdrafting
Ok, so this is still happening.
It seems like when I leave my computer for a while, and it goes into sleep mode (not sleep mode - but the hard drive sleeps - windows 7 Pro is still running), and I start back up again - it is the first drawing I open that this problem happens too.
 In the 2 jpgs posted, the "problem" one is version where text are shown as flat cyan lines, the arrow heads are empty, my area "polyline" is hollowed out, and my architectural ticks on my dimensions are empty as well.  When I close autocad down and restart the program again - the problem goes away.
Also, when I opened my drawing and it was buggered, I clicked on the buggered text, and changed it to annotative - it did nothing.  I did a screen regen - nothing.  I have to close and restart autocad.
I'll be honest - it is not the end of the world.  So I close, shut down and restart - big deal!  I am just posting this to see if there is a solution.  If no one has an answer, and this is the worst problem I deal with in a day... it's still a good day.
Just for the sake of asking - the f2 key and the text window disappearing or getting stuck behind the autocad window.  I have googled this to death - tried everything, and it still does not work.  Again.....save, close, re-start - problem goes away....
I am posting the file in case a hardcore user can tell me what I am doing wrong.  It only seems to be the bold text that goes wonky on me.
Message 9 of 13
john.vellek
Hi @tsdrafting,
What graphics card do you have installed? I am curious if this is a driver issue.
John Vellek
Message 10 of 13
tsdrafting
video card is all up-to-date with the latest drivers
Message 11 of 13
Vinayv4v
Try to Turn on your FILLMODE Variable <1> and regenerate the drawingwhen the problem is occuring. Run an AUDIT command to fix if it has got some errors.
Seeing line type in your drawing
Before
After Error
Or some Lisps may be running in the background which make changes in some of the system variable.
Just a suggestion.
Cheers,
Vinay Vijayakumaran
Message 12 of 13
barry2104
I've noticed the same Problem on various files I'm working on/with since upgrading to AutoCAD2016.
I run about 50 Lisps on Startup.
A restart of AutoCAD is the only fix I have come up with for now.
Hardware seems up to date.
anyone else experiencing this or has a fix?
Running AutoCAD Architecture 2020, in German
Message 13 of 13
tsdrafting
Hey Barry2104, I still have the same problem... just happened again two days ago.  You are correct, just have to close Acad and restart it.  Seems to fix itself - but sort of a pain.  I have researched this and found no solution as of yet... so it might just be the way it is.
