AutoCAD Forum
AutoCad 2016 - Retaining the Value in a lisp
3 REPLIES 3
308 Views, 3 Replies
All,
I have a problem getting it to retain the value that is entered for distance "dist" in the line code.  Can anyone shine a light on how I could achive saving the distance similar to the fillet or offset command?  Please see the lisp that I have attached below so you can see how the command runs.
Alex
3 REPLIES 3
leothebuilder
You will probably get a better response posting this in the lisp forum:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Kent1Cooper
Yes, over at the Customization Forum would be better [not a version-specific issue], but....
Take 'dist' out of the localized variables list at the top so it will be remembered after the routine is run.  Personally, I would give it a variable name more specific to this routine, so that in case you run various routines that might leave variable settings, no other one that happens to use a 'dist' variable will overwrite the value.  So if we call it something like BRKOUTDIST, replace this line:
(setq dist (getreal "\nEnter distance from intersection to breakout. "))
with something like this [untested]:
(initget (if BRKOUTDIST 0 1)); no Enter allowed on first use [variable doesn't yet exist]
(setq BRKOUTDIST
  (cond
    ( (getdist ; returns nil on Enter, only when allowed above by existence of variable
        (strcat
          "\nDistance from intersection to breakout"
          (if BRKOUTDIST (strcat " <" (rtos BRKOUTDIST) ">") ""); offer default prior value if it exists
        ); strcat
      ); getdist
    ); User-input condition
    (BRKOUTDIST); prior value on Enter [when allowed]
  ); cond
); setq
Using (getdist) instead of (getreal) allows the User to type a value, including one with feet and/or fractions if you use those, or pick two points on-screen.
Kent Cooper, AIA
in reply to: leothebuilder
Thank you for the heads up! I will be sure to post it in the correct place.
Forma Design Contest
