AutoCAD 2016 mc3.dll / mc3d.dllARX Command Error
Message 1 of 95
Upon opening a drawing in AutoCAD Architecture 2016 I get the error Exception in mc3.dll / mc3d.dll ARX Command. Unhandled Exception C0000005 (Access Violation Reading 0x0000) at Address C9C860F4h I am running windows 7 and Autocad is completely up to date. This randomly started happening after windows forced close the application to restart
Accepted solutions (3)
Replies (94)
Message 41 of 95
RidgewayPlumbing
When I select the drop down for help menu Autocad freezes.
Message 42 of 95
Here is how to resolve these crashes:
To resolve these issues:
  1. Go to Help > Desktop Analytics.
  2. Deselect the "Yes, I would like to contribute to this program" option.
  3. Click OK.
Next
  1. Go to Help > Customer Involvement Program.
  2. Select "No, I do not want to join the program at this time.
  3. Click OK.
  4. Restart AutoCAD or AutoCAD LT.
There are already over 3,500 error message sent in I'm told. There is a "backend" problem that will be fixed. Keep an eye out for a hotfix probably.
Message 43 of 95
I tested this in the office.
Do not rename or remove the dll.
Just ignore the box and continue to work. The box will go to the background.
When I replaced the dll I lost a lot of functionality as I said with spaces.
Ignore the issue and wait for Autocad to fix it otherwise you could use functionality.
We have had zero issues so far with just ignoring the pop up box
Message 44 of 95
Andreleslie,you might try typing in the command "customerinvolvementprogram" and "desktopanalytics"... and turning them off that way.
Message 45 of 95
I received a solution from Autodesk today...
  3. Click OK.
Next
  3. Click OK.
  4. Restart AutoCAD.
I hope that it's works!
Message 46 of 95
RidgewayPlumbing
I still cannot get to the help drop down.
Message 47 of 95
Just type in the commands at the command line REID ADDIS, RA BIM SPECIALIST | AUTODESK CERTIFIED INSTRUCTOR MICROSOL RESOURCES AUTODESK PARTNER OF THE YEAR NEW YORK | BOSTON | PHILADELPHIA NY 212.465.8734 | MA 617.229.7669 | PA 215.557.0770 microsolresources.com Follow us on Twitter | Like us on FacebookSee our Specializations
Message 48 of 95
RidgewayPlumbing
I had to open 2015 and change it from there then it worked for 2016. thanks god.
Message 49 of 95
Stated about an hour ago for my office as well. 12pm Pacific
We are running Autocad Arch 2016.
Message 50 of 95
robglass
Un-check access online help in Options. That along with the analytics and customer involvent un-selctions that others have mentioned has worked for me.
Keep AutoCAD from contacting the mother ship.
ACA 2016
Good luck.
Bob
Message 51 of 95
Bob,
I unchecked the checkbox in Options \ System \ Help - Access online content when available
However this did not fix the problem. Where is the checkbox located.
Thanks for your help.
N
Message 52 of 95
robglass
That's the one I un-checked. I closed and restarted AutoCAD. Since then I can access the help area. I have made all changes with a new or blank drawing open. AutoCAD didn't seem to crash imediately if it was not an existing drawing file, for some reason.
I also signed out of Autodesk A360.
Sorry it didn't solve your problem.
Bob
Message 53 of 95
I can not get to me help or any other commands before I am kicked out.  Do you mean I have to uninstall all my Autodesk programs and customization and then reset up all my users and each and everyones cusomizations.
This has caused my company tens of thousands of dollars.
Who set this is place to happen today?
Message 54 of 95
zalant
Autodesk Support
Autodesk Support
At this time, a solution appears to be as follows:
  1. Close any/all open AutoCAD instances.
  2. Browse to the following Windows registry key: HKEY_CURRENT_USER/software/Autodesk/MC3/ADAOptIn
  3. Set the value to 0.
  4. Launch the AutoCAD product and verify functionality has been restored.
To be on the safe side, back up the Windows registry prior to making any manual edits to it (like the one in the above steps).
Zac Travis
Message 55 of 95
MWALKOWSKI
Same here. What is the solution?
Message 56 of 95
thay mc3.dll vào C:\Program Files\Autodesk\AutoCAD 2016
link down mc3.dll của tôi https://drive.google.com/open?id=0B9iMW4gqlW6nWXdBN0pGc1dlblU
Message 57 of 95
robglass
Mine was set to 0. Interesting.
Bob
Message 58 of 95
SEEMS TO BE WORKING. WILL LET YOU KNOW IF IT DOESN'T WORK.
THX
Message 59 of 95
I BELIEVE THAT FOLLOWING YOU AND RCOLONS ADVICE SET THIS VALUE TO 0. IT WAS PROBABLY SET TO 1 BEFORE. THANKS FOR YOUR HELP ROBGLASS.
Message 60 of 95
Several computers at my company are affected as well.
A worldwide crash of a software program put out by a company whose programs facilitate a massive percentage of the architecture and engineering for the construction business around the globe...on November 5th, of all days.
I'm hoping this is just a coincidence, Autodesk, and not something more serious.
