AutoCAD 2016 mc3.dll / mc3d.dllARX Command Error
Message 1 of 95
Upon opening a drawing in AutoCAD Architecture 2016 I get the error Exception in mc3.dll / mc3d.dll ARX Command. Unhandled Exception C0000005 (Access Violation Reading 0x0000) at Address C9C860F4h I am running windows 7 and Autocad is completely up to date. This randomly started happening after windows forced close the application to restart
Accepted solutions (3)
Replies (94)
Message 81 of 95
mshoai
What helped me was replacing mc3.dll, in Autocad MEP program with the one in set-up However I am not sure if this is a real fix or not, but it did stabilize my autocad mep
Message 82 of 95
zalant
Autodesk Support
Autodesk Support
The last news I have is that it appears only the MEP whitelist file has been fixed. The one for ACA has not yet been swapped out with a good one. Also, be sure to reboot the machine, as stated in the article.
For now, shutting off Desktop Analytics is the best bet for ACA users. If you cannot access the program long enough to shut it off, you can switch it off in the registry.
Zac Travis
Message 83 of 95
mshoai
The whitelist.xml is not fixed for MEP same issues & problems but after replacing MC3.dll, at least autocad mep is again stable *Matt Shoai * *Systems Administrator & Plumbing Design Engineer*
Message 84 of 95
JonSmith
The problem whitelist.xml file itself can be fixed, if you really want to leave Desktop Analytics turned on:
  1. Browse to C:\Users\<username>\AppData\Roaming\Autodesk\ARCHDESK\2016\{5783F2D7-F004-0409-2102-0060B0CE6BBA}\7.8.106.0\MC3 (replacing ARCHDESK with BLDSYS for AutoCAD MEP)
  2. Open the whitelist.xml file in a text editor
  3. Replace all instances of "RumtimeName" with "RuntimeName" (note the 'n' instead of 'm')
It really does feel like Rum Time after that!
Message 85 of 95
mshoai
kind of late for that one first they said to delete the file so now the file is gone we can not edit it anymore However Autocad works fine, kind of slow in some areas, but overall is fine & the customer feedback & the other one basically are unrecognizable commands *Matt Shoai * *Systems Administrator & Plumbing Design Engineer*
Message 86 of 95
TSKSoftware
Provided you apply the reg key and delete or rename the xml file(s) then reboot, it should work ok. Take my batch file, check the paths in %userprofile% are relevant to your product, modify it if additional/different paths are found. Use the logon script for all the PC's if on a School domain to copy the batch file to each pc and execute it as administrator. This will fix the problem for most cases. It is also possible to fix rather than delete the xml file if required. With a little more information I will happily assist in applying the fix. M
Message 87 of 95
It's don't work at all with me,
And in one of your advices I search on, was to uninstall it and then reinstall it!
And here we go the same problem has pop out to me!
Message 88 of 95
Should I uninstall it and download ACA2015?
Message 89 of 95
I found an answer that worked for my company.
Go to the directory: "C:\Program Files\Autodesk\AutoCAD 2016"
Rename the file: mc3.dll to mc3.dll.bak
Now go to the directory: "C:\Program Files\Autodesk\AutoCAD 2016\Setup\en-us\Setup" and copy the file: mc3.dll
to the original directory: "C:\Program Files\Autodesk\AutoCAD 2016"
This seamed to work for all my users.
I saw other fixes but I could not get on AutoCAD long enough do them before I was locked out. Reboot. GOOD LUCK!!
Message 90 of 95
p_pacetti
Observer
Observer
I DID  IT  !!! THANK ALL OF YOU
Message 91 of 95
Victoria.Studley
Thank you all for your patience while we worked to resolve this issue.
The WHITELIST.XML file for both AutoCAD Architecture 2016 and AutoCAD MEP 2016 have been replaced on the Desktop Analytics server, and we've confirmed the following steps on several affected machines throughout the afternoon.
Here are the finalized steps to resolve this error for both AutoCAD Architecture 2016 and AutoCAD MEP 2016. The XML file is in a different location for each program, and the build version folder (the last one before MC3) will differ if you have the service pack installed or not.
To resolve the error:
    • Exit all Autodesk programs.
    • For AutoCAD Architecture 2016:
    • Navigate to this folder: C:\Users\<user>\AppData\Roaming\Autodesk\ARCHDESK\2016\{5783F2D7-F004-0409-2102- 0060B0CE6BBA}\7.8.44.0\MC3
    • Delete the file WHITELIST.XML.
    • Reboot the machine.
    • Launch AutoCAD Architecture 2016.
    • Enable Desktop Analytics, if you previously disabled it.
    • The program will download a corrected WHITELIST.XML file.
    • For AutoCAD MEP 2016:
    • Navigate to this folder: C:\Users\<user>\AppData\Roaming\Autodesk\BLDSYS\2016\{5783F2D7-F006-0409-2102-0060B0CE6BBA}\7.8.106.0\MC3
    • Launch AutoCAD MEP.
This has also been updated in the public AKN solution (it may take a little while to refresh). Additionally, any customer who sends in an error report after experiencing this crash should now receive a link to the public solution.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Message 92 of 95
Hi Victoria,
We had a couple of instances of this from our customers.In all instances, the offending whitelist.xml file resides in C:\Users\<user>\AppData\Roaming\Autodesk\ARCHDESK\2016\{5783F2D7-F004-0409-2102-0060B0CE6BBA}\7.8.106.0\MC3. Renaming or deleting the file resolves the issue.
Message 93 of 95
Thanks for the HELP. *DOUG E. GARTHWAIT*
Message 94 of 95
In ACA 2016, when I get to the point of enabling Desktop Analytics, it doesn't seem to automatically download the replacement Whitelist.xml file (nothing appears in the subfolder where I deleted it from).  Also, we've lost a number of functional editing commands through this whole mess.
Message 95 of 95
Moved:
zalant
Autodesk Support
Autodesk Support
Moved to the forums for Installation troubleshooting. Post did not pertain to the MC3 error discussed in this thread.
