AUTOCAD 2016 having issue to open .dwf extension file format
Dear Sir/Madam,
We have been getting below issue with AutoCAD 2016, .dwf file is not opening.
Earlier, it was opening with AutoCAD 2013.
We have checked on AutoCAD knowledge site to get info of supported file formats; it was listed but we are facing issue while opening it.
We are using the AutoCAD 2016 Version 20.1.49.0 and also PFA the attached error snap and one sample .dwf file.
Please help and suggest to resolve the same.
Thanks & Regards,
INFODBA
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
DWF files can't be opened with AutoCAD, not in current version of AutoCAD, not in 2013 or any other release.
The only thing you can do is to attach the DWF file using command _DWFATTACH (>>>details<<<).
Besides of everything else: you should install the current service packs.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
rkmcswain
DWF files cannot be "opened" with any version of AutoCAD.
Maybe you were using a different product called Design Review in 2013?
R.K. McSwain     | CADpanacea | on twitter
pendean
Community Legend
Community Legend
john.vellek
Hi INFODBA-NASIK,
The other responses are correct in that you can not "OPEN" a DWF within AutoCAD. You can use DWFattach and the file is treated as if it were an external reference.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
HI INFODBA-NASIK,
I am checking back to see if my post or others helped you with your problem.
Please add a post with your results so other Forum users can benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
