error openning autodesk apps
adsync.exe pops out when I open laptop
acad.exe pops out when I open autocad 2017
also revit 2016 is not working anymore ..
program cant start because api-ms-win-crt-runtime-l1-1-0.dll is missing
I checked in my control panels, and I have all the visual c++ versions, yet when I install visual c++ 2015, it always FAIL to setup
please help,
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Did you just installed the software or was it running fine previously?
With which message?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous
Welcome to the Community!
Please go through the following steps and let me know if the problem persists.
  1. Install Windows Updates:
    Go to Start - Control Panel - Windows Update
    Check for updates
    Install all available updates.
    After the updates are installed, restart your computer.
    After the restart repeat the steps above again until no more updates are available.
  2. Download the Visual C++ Redistributable:
    For Windows 64-bit
    Visual C++ Redistributable for Visual Studio 2015 (64-bit)
    For Windows 32-bit
    Visual C++ Redistributable for Visual Studio 2015 (32-bit)
  3. Run the vc_redist.x64.exe (64-bit) or vc_redist.x86.exe (32-bit) and select Uninstall
  4. Run the .exe again and select Install
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
john.vellek
Hi N.Khuder
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
