AutoCAd 2016 - Fillet Radius too large
Não aplicável
25.306Exibições
5Respostas
Mensagem 1 de 6
Não aplicável
AutoCAD 2016 doesn't make a fillet in a drawing ("radius is too large"). The weird thing is that AutoCAD 2010 didn't have a problem with this fillet.
Any ideas how to resolve it?
Thank you very much.
0 Curtidas
25.307Exibições
5Respostas
Respostas (5)
Mensagem 2 de 6
Vinayv4v
Solução aceita
Reduce your fillet radius value.
You may have zoomed in too much at the time of drawing. So you're object would have less lengths compared to the radius value you are giving.
Cheers,
Vinay Vijayakumaran
0 Curtidas
Mensagem 3 de 6
imadHabash
Solução aceita
>> The weird thing is that AutoCAD 2010 didn't have a problem with this fillet. <<
if you open the same source file from two different autoacd then you have to get the same result.but if you insert this file to another new cad dwg file then you may have different results if the units ( m,cm,mm) was not the same.
Imad Habash
0 Curtidas
Mensagem 4 de 6
pendean
Community Legend
Community Legend
Solução aceita
So what is your radius set to?
And how long are the two lines you are trying to "fillet"?
That always answer this type of question.
Don't assume anything: find out the details, dig a lot deeper into the settings. AutoCAD is an unintelligent software that relies on user settings to function.
Mensagem 5 de 6
Não aplicável
Thank you all for your responses.
I'll try what you suggested, hopefully it will work.
0 Curtidas
Mensagem 6 de 6
Kent1Cooper
Solução aceita
You may find FilletMax.lsp helpful -- available here.
But I'm curious about the assertion that an earlier version didn't have a problem but a newer one does.  Are they really starting with exactly the same conditions, and with exactly the same Fillet radius?
Kent Cooper, AIA
0 Curtidas
