File handling
File handling
File handling
Hello, I have an educator who in the past versions of autocad was able
to double click a project and it would open within the program in
tabs. Now with 2018 when opening additional files by double clicking
opens a new window of autocad and not with additional tabs. Is there a
way that he can just double click a file and each one would open in
autocad with several tabs. Thank you for your time.
Thank you.
user181
Make sure the SDI variable is set to 0.
Hello, where would I find that setting?
user181
You can just type it in on the autocad command line
The SDI is set to zero
user181
Here is a link to what the autodesk knowledge network says about it.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Double...
GrantsPirate
1. Open files from within AutoCAD.  Hint: create favorite folders in the open screen by navigating once to a folder, drag and drop, use that short cut from now on until no longer needed.
2. Drag the file and drop on the command line in AutoCAD.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
