AutoCAD Forum
autocad 2016 etransmit
14 REPLIES 14
Message 1 of 15
1991 Views, 14 Replies
hello
i have a strange problem
when i try to etransmit any file contains xrefs it saves all the xrefs as individuals dwgs beside the origenal file
for exsample i try to etransmit 1 file & the tree sees onle the file & the tamplet but the autocad write down that it will etransmit 43 files
thank you
14 REPLIES 14
Message 2 of 15
NickEvans
I also have this issue, despite having selected bind as my transmit option as Bind.
To be clear, I am using e-transmit to bind up x-ref'd models, so the vectorworks users can open them. I do get a bound model as output, but for whatever reason I also get the x-refs and plot configs. So one huge file plus all x-refs. Since this does not happen in 2015 using identical settings I can only assume this is a BUG INTRODUCED TO IMPROVE MY WORKING EXPERIENCE!
Message 3 of 15
pendean
Log into your subscription page, start a ticket, and report the problem: I can replicate it in 2016 as well.
Message 4 of 15
pendean
in reply to: NickEvans
AS I suggested to the OP, report the problem through the subscription portal.
Message 5 of 15
NickEvans
in reply to: pendean
Yes I did that already, though as an experienced autocad user I am aware that reporting things like this to autodesk is a bit like a broken pencil.
Message 6 of 15
till now there is no solution Smiley Frustrated
Spoiler
Message 7 of 15
pendean
Log into your subscription portal and report it. If no one does it, like the user before you, Autodesk doesn't get the impression many care to fix it. And it will never get fixed.
Message 8 of 15
sorry but i dont know how
Message 9 of 15
pendean
If you are on subscription, log in here
https://subscription.autodesk.com/ or https://manage.autodesk.com/cep/#products-services
click on the MANAGEMENT link a the top of the page
then the SUPPORT pulldown top-right of the page
select VIEW MY SUPPORT CASES
and start with TECHNICAL SUPPORT
then IDEAS & ENHACENMENTS once they confirm what you want is not there.
Message 10 of 15
I've recently come across this problem as well in AutoCAD 2016. Etransmit a drawing that has just one xreference, but the etansmit zip file has 29 autocad files totalling 65mb.
I have concluded that this problem seems to occur if the CAD file were originally from AutoCAD 2014 or 2015, as I do not have this problem for projects where all files originated from AutoCAD 2016.
By opening all AutoCAD 2014 models in AutoCAD 2016 and saving, seems to help this problem.
I'm running AutoCAD 2016 with SP1, Is there a hotfix available?
Message 11 of 15
john.vellek
Hi @Anonymous,
The eTransmit with external reference file issue is fixed in AutoCAD 2017. I am not aware of a hotfix for AutoCAD 2016.
John Vellek
Message 12 of 15
jeamy.baena
in reply to: john.vellek
Hi, John
Currently, we have the same problem (civil 3d 2015, 2016). I tested 2017 release, and the error was the same. (reinstalling, repairing, different OSs (W7,W10), various workstations)
Please see the following video
Do you know Any fix for that?
Thanks!
Message 13 of 15
john.vellek
in reply to: jeamy.baena
Hi @jeamy.baena,
I just did a test on my plain AutoCAD 2017 and was able to etransmit 28 files to a zip without issue.  Let me research a bit to see if this is Civil 3D specific.
John Vellek
Message 14 of 15
jeamy.baena
Thank you John!!
Message 15 of 15
john.vellek
Hi @jeamy.baena,
I haven't found anything specific to Civil 3D with eTransmit but one of our Specialists indicated that he has seen some errors with data shortcuts.  Is it possible to manually zip up a sample set of drawings so I can test on my side?
John Vellek
AutoCAD Inside the Factory
