AutoCAD Forum
AutoCAD 2016 does not read Arabic Font with XARB-style
19 REPLIES 19
Message 1 of 20
27333 Views, 19 Replies
I have a .dwg file that contains Arabic text with “XARB” style, and this text is incorrectly viewed in AutoCAD (in the screenshot below).
I have downloaded the XARAB.shx from this link and added it to AutoCAD font directory (C:\Program Files\Autodesk\AutoCAD 2016\Fonts). But the problem still arising.
What might be the issue here?
Any help is appreciated,
Hani
19 REPLIES 19
Message 2 of 20
imadHabash
Salam,
it's work fine with me.. !!!!
BUT just to remind you to check your Support File Search Path from OPTIONS>>> Files tab.
Imad Habash
Message 3 of 20
imadHabash
you can post just a single word as CAD drawing in case any difficulties . 🙂
Imad Habash
Message 4 of 20
in reply to: imadHabash
Many Thanks for the prompt response Imad,
I checked  the "Support File Search Path" and the fonts directory is enabled, but it does not work with me
Message 5 of 20
imadHabash
i'm always facing this problem here and there BUT it's always work fine.
post any text parts of your drawing for more and fast help.
Imad Habash
Message 6 of 20
Many Thanks for the prompt answer
But the issue of the drawing for the text  is same as hani told.
Could you please describe detail steps , how you have solved the issue.
Message 7 of 20
I've just copied this block of characters from the text: "Hgl,r______š", "fdhkhJ ohwm fhgl,rU"
Message 8 of 20
imadHabash
Salam,
Thers is no special procedure for what how it done . just paste shx file in FONTS folder then launch AutoCAD.
i've take your arab text from your post and there is...
I hope to help you more..
Imad Habash
Message 9 of 20
May you please post a compressed version of your fonts folder so I can use it instead of mine?
Maybe the problem is with my .shx files
Message 10 of 20
imadHabash
i use the same one you download it from your first post link .
Imad Habash
Message 11 of 20
May I know which version cad you are using...
Me too having the same problem..
Message 12 of 20
Hey everybody,
We use *.shx arabic fonts in our drawings. Everything was working flawlessly in AutoCAD 2015. We could write and print (to PDF or plotter for instance). But when we try to plot or convert a drawing to PDF in AutoCAD 2016, all *.shx fonts rotate and become upside down in the PDF file ro plot result !
Can anybody help ?
Message 13 of 20
artc2
The upside down plotting is a known bug in AutoCAD 2016.  It is currently being worked on.
Message 14 of 20
Dear, As you said you have dwg contains Arabic text with “XARB” style this text is incorrectly viewed in AutoCAD.
Problem: XARB” font style incorrectly viewed on drawing.
Reason:  Missing font file XARB.shx (C:\Program Files\Autodesk\AutoCAD 2016\Fonts)
I had seen in your screenshot you have missing font file XARB.shx (C:\Program Files\Autodesk\AutoCAD 2016\Fonts)
But you downloaded font file XARAB.shx instead of XARB.shx You have to understand that both files are not same.
Solution: My suggestion is download XARB.shx & put it (C:\Program Files\Autodesk\AutoCAD 2016\Fonts). Then your problem will be solved.
Note: I attached XARB.shx font
Tags (1)
Message 15 of 20
patrick.cc01
it worked! thanks for the attachment. 😁
Message 16 of 20
linkonpandit47
Could you please share the xarab.shx font?
Message 17 of 20
pendean
in reply to: linkonpandit47
Message 18 of 20
linkonpandit47
in reply to: pendean
Thank you for your concern. I have seen that xrab.shx file too and already downloaded and installed it.  But unfortunately, this is not the one.
I am looking for the xarab.shx font.
If anyone has it please, kindly share.
Message 19 of 20
pendean
@linkonpandit47 Why not try a more language focused AutoCAD forum for your query then
https://forums.autodesk.com/t5/bramj-alatwkad/bd-p/6120
And a websearch if all else fails seems to have some options https://www.google.com/search?q=xarab.shx+font+download
Message 20 of 20
linkonpandit47
Yeah, I tried downloading from Google Search, and the closest one they suggested to me is this forum. Thanks for the other suggestion though.
AutoCAD Inside the Factory
