AutoCAD 2016 - Cant explode blocks in block editor
Message 1 of 14
Just started using version 2016 and found that I cannot explode a block that I inserted inside block editor.
I saved the same drawing down to version 2011 and it allows me to explode blocks within block editor.
Did something change with version 2016?
And yes the block has the attribute selected to allow exploding.
Replies (13)
Message 2 of 14
Update:   So the block can be exploded using the "X" hot key, but will not explode using the icon.
Seems like a software bug?
Message 3 of 14
john.vellek
Hi @Anonymous,
Welcome to the Community!
If I understand correctly, you have a block in your drawing. When you select the explode icon and then select the block to explode it will not work. If you type 'X' and then select the block it will explode.
Or, is it the order you are selecting in? Check your PICKFIRST variable and set it to 1. Please let me know if this corrects the problem or if I am misunderstanding the issue.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 4 of 14
You are correct.
I am trying to explode a block that I inserted within a block while in block editor mode.
It doesn't matter if I select the block first, then the explode icon.... or if I select the icon, then the block.
I can't seem to find the PICKFIRST variable you mentioned (see screen shot)? but don't believe it will have any effect based on information above.
Message 5 of 14
john.vellek
Hi @Anonymous,
Can you attach the drawing so I can determine it it a problem with the drawing itself or if it is something else?
John Vellek
Message 6 of 14
Open up FIRST BLOCK in block editor, then try to explode SECOND BLOCK using icon.
It won't explode for me.
But will explode if I select SECOND BLOCK and use the "X" hot key.
Message 7 of 14
john.vellek
Hi @Anonymous,
I am trying to duplicate the issue but want to make sure I am following the same steps.  Please take a look at my Screencast to see if I missed something.
John Vellek
Message 8 of 14
Not doing it the same way.
1) Open up the block called FIRST BLOCK in block editor.
2) Within block editor, try to explode the block called SECOND BLOCK
Message 9 of 14
john.vellek
Hi @Anonymous,
Thanks for the clarification. I opened First block in editor. Then using the icon for Explode I selected Second block and the command worked fine.
So....let's try this. Please create a new user account (full administrator), log on to your workstation and see if the problem persists.
Please post your results.
John Vellek
Message 10 of 14
john.vellek
Hi BCA8888,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 11 of 14
Logging on as a new user seemed to work.
What would you suggest I change in my own user profile to correct the issue?
Message 12 of 14
john.vellek
Hi @Anonymous,
We could try and copy the new profile stuff over but that can create its own problems.
Is it possible to do a Reset Settings to Default to see if that helps?
John Vellek
Message 13 of 14
No change.
Brian Adamski, Senior Project Manager
Foth Production Solutions, LLC
2121 Innovation Court, Suite 200
P.O. Box 5125
De Pere, WI 54115-5125
Ph: (920) 496-6753
Cell (920) 246-5491
www.foth.com
________________________________
IMPORTANT NOTICE
This communication including any attachments, (E-mail) is confidential and may be proprietary, privileged or otherwise protected from disclosure. If you are not the intended recipient, please notify the sender, permanently delete this E-Mail from your system and destroy any copies. Any use of this E-Mail, including disclosure, distribution or replication, by someone other than its intended recipient is prohibited.
This E-Mail has the potential to have been altered or corrupted due to transmission or conversion. It may not be appropriate to rely upon this E-Mail in the same manner as hardcopy materials bearing the author's original signature or seal.
Message 14 of 14
So I exported my user profile from 2011 and imported it in 2016.
This got rid of the top panel and gave me back the tool bars I always had in 2011, including the EXPLODE icon shown in the attachment.
Now I can explode the block using the icon.
Thanks for the help.
I'm still not sure why the top panel explode icon in the 2016 HOME panel did not work.
