AutoCaD 2016 cannot open a file created by AutoCad 2014
wlessor
Observer Observer
Message 1 of 11
wlessor
Observer
Observer
Its perplexing, I reset the 2016 and attempted to open and it says its not compatible with my version. It shouldn't have an issue opening something that was created on the 2014 version. Any ideas, support was a dead end.
Replies (10)
Message 2 of 11
CGBenner
@wlessor
Welcome to the Community.  Has the file always been in your possession?  What I mean is, if someone else had the file and opened it in a newer version of Acad, and then sent it back to you, that would explain the error.
Chris Benner
Message 3 of 11
pendean
Community Legend
Community Legend
Your DWG file is corrupt beyond repair, or someone with AutoCAD 2017 or newer last saved it for you.
Go grab the free DWGTRUEVIEW program from Autodesk to see if the file opens there, then knock it down to an older format in the viewer so you can use it https://www.autodesk.com/products/dwg-trueview/overview
Or share your DWG file here for others to try.
Message 4 of 11
wlessor
Observer
Observer
It was created in 2014 Auto Cad and when trying to open it in 2016 it fails. True viewer opens it just fine but my user need to edit it. Thanks for the quick response.
Message 5 of 11
pendean
Community Legend
Community Legend
@wlessor wrote:
...True viewer opens it just fine but my user need to edit it. Thanks for the quick response.
As I noted in my first reply, with DWGTRUEVIEW open, convert the file down in the viewer for your older program to be able to open it, like this (aim for an older format)
Unless your AutoCAD 2016 is also messed up.
Message 6 of 11
Patchy
I reset the 2016 ??
You installed, reinstalled, repair?  something didn't work right?
Which version of Windows (2016 is not support with Win10, 11) seems like there isn't enough information here.
Message 7 of 11
wlessor
Observer
Observer
Windows 11,
Message 8 of 11
Patchy
The problem is your Autocad 2016 is not compatible with Win11, not because version 14 of the dwg.
All the same as shown here:
Message 9 of 11
pendean
Community Legend
Community Legend
@wlessor wrote:
Windows 11,
Free (and not so free) tips here may help, explore:
https://blog.longbowsoftware.com/category/autocad/autocad-2016/
Message 10 of 11
Patchy
If successfully installed, can it be activated?
Message 11 of 11
wlessor
Observer
Observer
It was installed and licensed.
