AutoCAD Forum
AutoCAD 2015 Start up Screen
4 REPLIES 4
357 Views, 4 Replies
I just installed 2015 and when I open it the first screen that comes up says "Learn" & "Creat" at the the bottom with different categories at the top depending on which section you have selected at the bottom. I really need AutoCAD to open up to the main model spade screen from the begining. How can I get this to switch back?
4 REPLIES 4
matthew.d
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Could you provide a screenshot of what you are referring to?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
is there a "do not show this message again" box to check
GrantsPirate
set STARTUP to 0.  Close the session of AutoCAD and reopen to try it.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
in reply to: GrantsPirate
Thanks for the help everyone! Also, heres an article someone else lead me to that lays it out for you as well. http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
