I just installed 2015 and when I open it the first screen that comes up says "Learn" & "Creat" at the the bottom with different categories at the top depending on which section you have selected at the bottom. I really need AutoCAD to open up to the main model spade screen from the begining. How can I get this to switch back?
Solved by GrantsPirate. Go to Solution.
Hi @Anonymous,
Welcome to the community!
Sorry to hear about the issue. Could you provide a screenshot of what you are referring to?
set STARTUP to 0. Close the session of AutoCAD and reopen to try it.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Thanks for the help everyone! Also, heres an article someone else lead me to that lays it out for you as well. http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
