AutoCAD Forum
AutoCAD 2015 - Field update settings changing by itself?
2 REPLIES 2
342 Views, 2 Replies
When the "save" box is checked and all others are left unchecked, we select apply and close, then apply within options window. When you go back to check the settings it will check either regen or plot or both as well as save? why does this automatically add a check to these other options? save is all we want checked? Using FIELDEVAL settings did not fix the issue either. Thanks
2 REPLIES 2
pendean
What's your field paramaters that they change after a regen? If you want the initial info to remain static after creation, do they need to remain fields by chance?
in reply to: pendean
This is used with the time date stamp. The only time the time/date can change is on a save. It is critical that this time date stamp does not change on a regen or plot. Thanks
Technology Administrators
