When the "save" box is checked and all others are left unchecked, we select apply and close, then apply within options window. When you go back to check the settings it will check either regen or plot or both as well as save? why does this automatically add a check to these other options? save is all we want checked? Using FIELDEVAL settings did not fix the issue either. Thanks
