Solved by nrz13. Go to Solution.
To be fair, whether the Ribbon causes more total clicks, or less total clicks depends on the tasks and the workflow of the user. Contextual Ribbon states for example can save a large number of clicks/picks. I'm happy to use the Ribbon when it makes sense, but when it doesn't, I want to be able to get it the heck out of my way.
I had better luck using the Migrate Custom Settings utility which came with 2015. It picked up EVERYTHING from my 2014 installation! I was startled.
It's really easy to get back the classic workspace!
1) First of, type RIBBONCLOSE and hit Enter. Ribbon goes away.
2) Then, type -TOOLBAR then select or type STANDARD and then select or type SHOW
There you go. Classic workspace is back!
3) By right clicking on the toolbar you can add the tools you want to have.
Thanks for trying...when I type in "Toolbars" I get the CUI pane....er pain. with no option to select or type "Standard"
Be careful: it's -Toolbar
(hyphen in front and no "s" on the end)
Okay I give....can't get back to toolbars. Here's another question. Why is Drafting & Annotation not a workspace option? I just get "Architecture" and Customization as workspace options....
Our IT simply updates my Autocad each year and does not allow me to migrate anything.
Hi, how to import from AutoCAD 2004 (full version) to AutoCAD LT 2015 ? Is that possible ?
Is it possible to import from AutoCAD 2013 student version to AutoCAD LT 2015 ?
Thanks !
Hi superlayla,
In my opinion I wouldnt try to import your settings from 2004 to 2015. There have been a lot of changes between 2004 and 2015 and I would expect importing settings from such an old and unsupported version would cause more problems than it would solve. setting up toolbars again 30min to 1 hour, problem solving, error finding and ultimately reinstalling because your OLD settings data has corrupted the program 1 hour .to several days
Importing from 2013 to 2015 should be easy enough using the 'migrate custom settings' tools (PROGRAMS>AUTODESK>AUTOCAD[VERSION]>MIGRATE CUSTOM SETTINGS)
I would, in my opinion, at least try to work with the new ribbons and quick access menus before importing previous settings because if Inventor is anything to go off there wont be any classic menus soon.
P.S. The right click drag function is actually very useful once you get used to it, definitely faster than classic buttons or ribbons for heavy use commands.
Hope that helps.
C
If I import the classic workspace from AutoCAD -student version- to AutoCAD LT, will it show the banner "made with educative version.." ?
I really dislike the new workspace... at school, I learned with the classic, at my job, we work with the classic even in ProjeCAD... this new workspace is not very useful and it's not quick to access to the tools. Everything is hide. I'm a little disapointed to don't have the classic workspace, that's not smart from AutoDesk.. 😕
Everyone working for a long time with classic interface has the same opinion, and it needs some hours/days to get familiar with it and some more days to love it, you just need that time to work with the ribbons (and see the contextual ribbons working for you).
You always have the change to create your own workspace, it's not Autodesk keeping you away from creating one looking like classic.
Start command _-TOOLBAR ==> _ALL ==> _SHOW ... then command _RIBBONCLOSE ... and now arrange the toolbars to the positions you like to have them, at least save the workspace with a new name and that's it.
- alfred -
I have migrated the user settings from 2014 but 2015 is still unusable.
Way to go Autodesk, as a self-empolyed enginer, I relish wasting my time trawling though forums etc. trying to find a fix that doesn't exist for a problem that shouldn't exist.
I am both a tablet user and a mouse user. I would prefer my 16 button tablet running three menu lists (out of possible four button combinations - my memory is only so good). As fast as I can think of the thing I want to do, I generally have already issued the command and I am working. For years at AMEC, people around me who have more than a decade in CAD could not figure out how I drafted so fast. Between the absolute pointing which your body learns and quickly controls more accurately, and the buttons on the fly, it makes an immense difference in GIS and other super fine and delicate CAD work. I would not see a benefit for something like REVIT which I also use though. Autodesk is too concerned with giving users what they feel they should use rather than what people actually want. In the process, many new draftsman are somewhat dumbed down I would have to say. They hunt and peck draft instead of focused line work processing. Some have a desktop that looks reminicient of old Microstation with a maze of icons everywhere and the smallest actual viewing window so they spend their days zooming or panning or get neck lock from crossing over multiple monitors. My current tablet machine is running on a Vtablet driver which is the end of its life for this I suspect. It works but isn't as fast or smooth as the original Summa driver which was incredibly smooth and fast. The problem with all this automation and simplifying of drafting so that even inexperienced people can do something is that they tend to. Engineers get in and 'make some changes' just because they can. Even if they don't really understand all that they have done or screwed up in the process. Some drafting tasks will be hard to fully automate and require extensive linework manipulation and work. Looking away from your incredibly small linework target to find an icon or issue a command is not useful then. So back to quick keystrokes or? Since I can't program a cursor button to do the job. Although, there is such a thing as a 16 button mouse apparently. Maybe that will be my next move if Autocad keeps allowing the legacy controls. If they don't. Then maybe it is time to quit upgrading with little improvement overall. My biggest frustration with Autodesk is that with any upgrade, you have to whittle your way to what you want to work with. Instead of giving you the base platform and letting you turn on anything you want to try or adapt. I think that Autodesk does most of this rework each year just to show some reason for customers paying for subscription. But that will only go so far. Sorry to ramble. I have spent the day installing 2015 versions of Map, Raster and Revit plus various other packages. Not really impressed so far and I needed to search for yet more fixes for their screwups.
I will try to be more like you and adapt I guess. That seems to be what big brother wants no matter what. ha ha Keep on drafting! Cheers
I don't know about 16-button mice, but I found this 20-button customizable mouse real quick. I'm sure there are plenty of others out there.
http://gaming.logitech.com/en-us/product/g600-mmo-gaming-mouse
An interesting thought - upload your cui onto AutoDesk 360 (or sync it) and once migrated, pull the cui file down. Hey presto - you can manually load the cui commands back in.
Your 360 account does not need to tie in with your licence account. (Well, mine doesn't...)
Thank you! Tried this and it works. Just reset back to ACAD Classic for the rest of the office. It's not that we don't accept changes. We prefer to work efficiently for productivity. And Acad Claasic is what rocks our boat, thankyouverymuch.
Yes, another example of Autodesk acting like our elected officials and bullying users by ignoring what most of us want and simply giving us what they think is best for us — despite massive complaints about the Ribbon supplanting classic Toolbars. Not to mention Autodesk seems to continually ignore the fact that monitors are getting WIDER, not TALLER, obviating any 'space-saving' benefits of the Ribbon.
There are hundreds of great ideas out there (just look at the Wish Lists from the past ten years) that Autodesk simply ignores and yet persists in giving us 'improvements' like the Ribbon and touting 'new' features such as different colored backgrounds (which, BTW, we've been able to adjust for years) and on and on. Someone put it quite well when they said that "It was as though Microsoft sneezed and Autodesk (with the Ribbon) caught a cold."
This latest effort ant partially 'denying' users any easy access to our Classic Workspaces is, as I said, another example of corporate bullying that further undermines Autodesk's credibility.
It seems Autodesk's focus is on other software divisions and AutoCAD is simply being left behind, with fewer and fewer genuinely valuable features being brought forward. I wonder if there are even any working (i.e., 'production') Architects on staff, as more and more features seem to have novelty value but of less and less practical use a production environment.
This is pretty much a rehash of hundreds of other posts from working Architects, so nothing new. Although, I still wonder why my $5000+ Revit suite can't give me Ortho to Perspective with one mouse click when my $600 SketchUp program can. Go figure.
