AutoCAD Forum
autocad 2014
3 REPLIES 3
306 Views, 3 Replies
autocad 2014
when i want to draw an un straight line on autocad it became dash line and sometimes unvisible ... and also the circle or a curve ..... please help
3 REPLIES 3
seems to work fine for me. double check Z levels perhaps? maybe try using "flatten" command
ennujozlagam
hi, nothing wrong with your drawing, when want to draw staight line just press F8. set your line type "bylayer". go to your layer, set your linetype tp "continuous. in command prompt type viewres > set value to 20000. hope it helps. thanks
pendean
I can't reproduce the issue in your file either.
AutoCAD Inside the Factory
