AutoCAD Forum
AutoCAD 2014 Not Recognizing Commands Entered Quickly
4 REPLIES 4
5533 Views, 4 Replies
As the title says, when several commands are entered very rapidly, i.e. zoom + extents (z+e), AutoCAD doesn't seem to recognise the second command. I believe there was a command that I came across a while back that adjusted the time delay between entered commands but I am unable to remember or locate it.
Anyone know of a way to decrease the minimum time between entered commands?
David
4 REPLIES 4
GrantsPirate
INPUTSEARCHDELAY is the variable, 1000 = 1 second
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
in reply to: GrantsPirate
That didn't quite do it. All INPUTSEARCHDELAY does is change the time between the suggested autocomplete command box appearing I believe.
Yong.Jing
Have you tried to modify the mouse configuration?
By the way, could you tell us the OS you were using?
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
in reply to: Yong.Jing
I am using AutoCAD 2014 on a Windows 7 operating system.
And no, I haven't tried modifying the mouse configuration yet.
AutoCAD Inside the Factory
