As the title says, when several commands are entered very rapidly, i.e. zoom + extents (z+e), AutoCAD doesn't seem to recognise the second command. I believe there was a command that I came across a while back that adjusted the time delay between entered commands but I am unable to remember or locate it.
Anyone know of a way to decrease the minimum time between entered commands?
David
INPUTSEARCHDELAY is the variable, 1000 = 1 second
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
That didn't quite do it. All INPUTSEARCHDELAY does is change the time between the suggested autocomplete command box appearing I believe.
Have you tried to modify the mouse configuration?
By the way, could you tell us the OS you were using?
