When I try to print a drawing or modify a page setup in AutoCAD 2014 the program hangs, never recovers, and does result in an error message. I have tried changing the print settings in options but it didn't correct the problem. I tried printing drawings that I haven't previously worked on and I get the same problem. I can print "my" drawings on other machines without the program hanging. So I narrowwed it down to my machine but I can't figure out what is causing the problem. I can print using batch plot but I cannot edit page setups. I haven't had this problem before and I'm not sure what started it as I have not made any modifications to my AutoCAD setup.
Solved by ampster40. Go to Solution.
It sounds like your dialog is coming in off the screen where you can't see it. Press ALT + SPACE + M then hit one of the arrow keys and then move the mouse and see if the box shows up.
Pagesetup opens fine but when I try to modify the active setup which would open the plot dialogue it hangs.
I had the same issue... what I found was that I had the two different file locations for the "Plot Style Table Search Path" and once I deleted one - it worked again.
