Autocad 2014 freezes when dragging objects to copy, move or to create a block. The only way to recover from this is to 'end process' from the task manager. Work from last save is lost.
Solved by Alfred.NESWADBA. Go to Solution.
Does it happen on all files or just one?
Have you tried AUDIT to see if it finds anything wrong in the file?
Also might check out DGN purge to see if there is any junk in there causing issues: https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-C2-AE-dgn-ho...
CADnoob
if it's independent from dwg-files then let's look to the application and environment:
- alfred -
