What were you doing when it crashes? Is it on all dwgs or just one?
a drawing will come up but it crashes with any operation, line, print
windows 7
no changes to computer before problem started.
since had computer cleaned, scanned, firewalls and antivirus off for the moment so they would not effect uninstall and install
tried the repair options too
worked last friday but not monday has been fine sinsce initial install 2013
Considering uninstall of whole design suite, or a new computer
It looks like a complete uninstal would be hours and then a reinstall
have you tried turning off hardware acceleration?
Command: 3dConfig
Next to Hardware Acceleration, Click Off
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Hi @Anonymous,
If this seemed to affect the Ribbon I suspect that this is a .Net Framework issue. Is it possible to uninstall .Net Framework 4.7, reinstall 4.6.2 and then reinstall 4.7?
Hi @Anonymous,
Here are instructions for a clean uninstall if you choose to go that method. Did you check to see if the .Net Framework 4.7 was installed? Did you try removing it and then reinstalling 4.6.2?
