I am using Autocad 2013 in another PC and I am experiencing two issues with eTransmit command:
1. Each time i use eTransmit, the dwg file is being placed inside a folder in the zip file. (this folder contains just the dwg file. All other items - xrefs etc - are in seperate folders).
In the past, the dwg file was always a single file in the zip and all the xrefs and other items were in seperate folders. Any ideas how to get back to the original way of creating the zip files?
2. Previously when creating the eTransmit zip file, its location was always the location of the dwg that I was currently processing. If I change the path options in the Modify Transmittal Setup, the location will always be the one I indicated and not automatically the current one.
Thank you for your help
