Viewbase missing objects
gilbert.diwata
gilbert.diwata
I have problem using viewbase, its like after an hour using viewbase command  the viewbase objects turns white to maroon color and some times my objects on the viewbase disappeared. I am currently using Autocad 2016. Can someone please help me because I need to use viewbase for my project that is due next week .Thanks.....
Accepted solutions (3)
imadHabash
i suggest to disable hardware acceleration from  GRAPHICSCONFIG  command and see if any changes.
Imad Habash
When things turn dark red I save and restart. Have the parts that disappear been edited? Is it the original version of the part selected for the viewbase, or are you now looking at a copy of the original that needs to be added back into the selection?
When you first notice this happening, left-click the parent view, select 'Edit View', 'Model Space Selection. This will bring you back into model space where you can confirm all of the desired objects are selected as being part of that base view.
john.vellek
Hi @gilbert.diwata,
A lot of improvements were made to the reliability of Viewbase in AutoCAD 2017.  Do you have access to that version or newer?  You typically don't want to move Viewbase views from version to version but you could grab a Trial of 2018 and see how the model performs in that version.
John Vellek
gilbert.diwata
I think ill stay using 2016 until the end of this semester before I upgrade it to 2018 because all my files are in 2016 and I dont want to screw it up. But thanks though
