3D PDF Tutorial For AutoCAD 2016/17/18
omorah
omorah
I have been looking for a more current ( AutoCAD 2016/17/18 ) 3D tutorial in PDF. I have a handful of AutoCAD 3d tutorials, but they are for older versions with different functions than the current versions of AutoCAD. Yes, all 3Ds may have same concept but with newer versions of AutoCAD (toolbars), it would be nice to have a more current PDF tutorial. Also, yes, there are tutorial videos, but I would also like to use a PDF to learn/practice 3D drawings.
Thank you!
john.vellek
Hi @omorah,
I am not aware of any specific PDFs on 3D training in AutoCAD.  I found this conceptual article that might be a start.
When I did some Internet searching, I found that most articles come from EDU Institutions.  Have you considered taking some actual coursework from a ACT or from a school?  Some of the curriculum might be exactly what you are looking for. Let me know if you need some URLs
John Vellek
omorah
@john.vellekwrote:
Hi @omorah,
John, first, thank you for your search, well appreciated. Let me expand on my reason for looking for a PDF. Maybe I should have mentioned this in my post.  I have already done AutoCAD 3D some years ago; did well with pipes, tanks, fixtures, in both mechanical and architectural office practices. This was some ten years ago. Now, I have forgotten most of the way around doing it the way I used to, due to the fact I moved to another office that did not use 3D. So, now, I just need to 'brush' up on 3D again to get back into the groove. On such note, I was just looking for PDFs to go through quickly.  I have the one in your link, and many others also. I currently have about four I am using, but none is for the more current version of AutoCAD, but can still get around easily.
However, the main reason why I need to get back to my 3D experience is because I am about to start learning Revit Architecture.  I have the 2018 Revit and a very good book on it. So, if I don't get back in the groove of the AutoCAD 3D, I will not after getting into Revit. An analogy would be learning how to drive a car with an automatic system and going to try to drive a manual transmission.
Hopefully I will be done with my 3D practices this weekend then start on Revit by next week.  In conclusion, I think I am fine now with the PDFs I have.
Thanks again John.
