Autocad 2013 eTransmit settings restore
n_ape
Observer
Observer
n_ape
Observer
Observer
I am using Autocad 2013 in another PC and I am experiencing two issues with eTransmit command:
1. Each time i use eTransmit, the dwg file is being placed inside a folder in the zip file. (this folder contains just the dwg file. All other items - xrefs etc - are in seperate folders).
In the past, the dwg file was always a single file in the zip and all the xrefs and other items were in seperate folders. Any ideas how to get back to the original way of creating the zip files?
2. Previously when creating the eTransmit zip file, its location was always the location of the dwg that I was currently processing. If I change the path options in the Modify Transmittal Setup, the location will always be the one I indicated and not automatically the current one.
Thank you for your help
john.vellek
Hi @n_ape,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I have seen the path to the etransmit location issue before.  The solution I found was to perform a Reset Settings to Default to correct the location. If you don't alter the location in the transmittal setup, I believe it uses the current folder.
Here is a snapshot of my Registry settings for eTransmit if you are comfortable using the registry editor (Please use caution and only edit at your own risk)
John Vellek
john.vellek
HI @n_ape,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
n_ape
Observer
Observer
Thank you very much for your help. It worked as soon as I reset the settings.
