AutoCAD 2013 Crash Error when re-installed
This widget could not be displayed.
Hi everyone,
I am using AutoCAD 2013 version. It was working well for me but once I uninstalled it because of it's inventor server not working, when I try to install it back again it starts creating a problem and become closing in crash.
Can anyone help me out how to fix this problem...???
I appericiate your kind response.
Regards
@Anonymous,
john.vellek has edited your subject line for clarity:AutoCAd 2013 Carsh Error
Replies (17)
pendean
Community Legend
Community Legend
So this is an installation problem? find your installation log file and post it here, the problems might be listed in it.
Installation log file?
You mean the folder in which AutoCAD is being installed....??
john.vellek
Hi @Anonymous,
Welcome to the Community! The install log should be kept in your Windows User Profile Temp folder.
Please attach it so I can take a look for you.
John Vellek
Sorry to say...
But I don't know how to do it....
john.vellek
HI @Anonymous,
the log files should be in this folder on your workstation:
C:\Users\v<USERNAME>\AppData\Local
John Vellek
john.vellek
HI @Anonymous,
Were you able to locate the logs files for me so I can determine what caused the crash when you reinstalled?
I would like to assist you in resolving this problem.
John Vellek
Now I'm having trouble of unexpected shutdown with all of my Autodesk Apps i.e. AutoCad, Max & Revit....
Even those whom I didn't reinstalled....
I also have limited internet access so please suggest me any method that i could do at my own.....
After shutting down an error report appears on screen that's contains some files from installation log folders. Are these the problm??? I track there location and delete them but it still didn't work....
Alfred.NESWADBA
>> After shutting down
Which software? (or the workstation?)
Please show it to us, it's difficult to make suggestions for a message "an error ..." .. not knowing what the error message/report showed you (but not us).
"Some" is not that good as info, which files did it contain?
Back to your first question (besides of reinstall might have not been necessary for solving the Inventor server failure message): when you reinstalled it:
  • have you first uninstalled AutoCAD?
  • did you follow the rules for clean uninstall?
  • or did you just a repair install?
Next questions to know more about that:
  • you had local installation files or the DVD from AutoCAD 2013 and installed that from local resources or did you install from Internet-"Install Now" option?
  • have you had disabled your firewall
  • have you had disabled antivirus software
  • did you run the installation as administrator
A lot of questions, but they are needed to know (as exact as possible) what your current state is.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
Please look at @Alfred.NESWADBA's post and provide some information. unfortunately, the log files would have helped to determine what is going on with your installation and it would have been better to attach them to the thread.
Do you receive any error messages?  If you would create a new administrative User account and logon with it do you still have the issues.
Please also, tell us what operating system you are running, how much RAM and disk space you have and also the type of graphics card.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with your status/results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Yes i have installed AutoCAD from CD.
I have disabled firewall and antivirus.
I have installed it as administrator..
john.vellek
HI @Anonymous,
Does the software complete the installation or does it fail before that? If you could attach a setup log that would be helpful (it is in your Windows profile\Temp folder).
If it fails after you installed and when opening or working with a drawing please let me know.
John Vellek
I have changed windows of my PC. Reinstalled AutoCAD. It's properly installed and all functions are working accept inventor.... when i try to generate different views of a 3D model. It's prompt "Inventor Server Failed to Load" and runs move command automatically....
Alfred.NESWADBA
So it does not crash any more?
To which version of Windows? (just because AutoCAD 2013 is not supported for Windows 10 >>>more info's<<<)
Look to >>>that thread<<< (and others already existing in www with suggestions and solutions.
HTH, - alfred -
Alfred NESWADBA
john.vellek
Hi @Anonymous,
Please update your post with the status of your issue. Please also respond to @Alfred.NESWADBA's last post so I can make sure things are running properly for you.
John Vellek
Sorry for late response.
I'm using windows 8. And i reinstall my windows & AutoCad. Both are working well now. No crashing anymore: )
