Autocad 17 - Can not see through masked text when moving them
Message 1 of 11
Just started using Autocad 17 from Autocad 14 and I'm having an issue with moving background masked mtext items around in the drawing and not being able to see through the background mask as I'm moving them like you could in Autocad 14.
When I move a masked mtext object in 17 everything is blacked out within the border of the mask, so if you are trying to move a masked text object
to sit on top of a line without masking the line, it's kind of a hit and miss operation to move the object into place without covering the line.  In Autocad 14 you could do this easily because you could see through the masking and see the objects in back so that you could place the object right where you needed to.
Does anyone know how to get this functionality back for Autocad 17 and newer versions?
Replies (10)
Message 2 of 11
steve-NEO
Have you tried working with the DRAWORDER command?
---Steve
Message 3 of 11
pendean
Community Legend
Community Legend
Define "mask" please: I see from an earlier post you were using different methods.
As a general rule the problem you describe usually means your video card cannot keep up with 2017 since it's an ability here. Update your video card driver to see if that helps and post a screenshot of your GRAPHICSCONFIG command pop-up.
Message 4 of 11
WarrenGeissler
@pendean is right about your graphics options affecting this. Another trick is to use grips for moving / rotating masked text. That will allow you to "see through" your masking.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
Message 5 of 11
We have brand new high dollar computers and video cards running Autocad 17 and all machines experience this issue.
I believe it is unique to later versions of Autocad post Acad 14 or we are just missing a setvar setting or something that was
default in earlier versions of Autocad.
Create a string of mtext, give it a background mask and in this example give a large mask area that extends well beyond the text itself,
now use the move command or the copy command and select the text and move it across your drawing, everything behind the masked text as you are moving it around the screen is blocked out (black) until the text mask moves beyond it.
In Autocad 14 you could do the same steps above and as you are moving across your drawing with the masked text, you could see the objects and linework
behind the mask so that you could place the masked text exactly where it needed to be.
Is this just something that was taken away in later versions of Autocad?
I'm hoping it is just a setting or something.
Message 6 of 11
Using grips to move the background masked text objects does work so that you can see through the masking as you are moving the text object around.
But why does it not work that way for the move and copy command like it did in older versions of Autocad???
Thanks Warren for noticing that it does work correctly for grip moves, appreciate that.
Message 7 of 11
pendean
Community Legend
Community Legend
Post a dwg with the problem: I am unable to replicate your described issue.
FYI, high-dollar computer tells us nothing, post actual specs/details if you want.
And no use comparing R2017 to R2014, a lot changed with graphics requirements between the two.
Message 8 of 11
jggerth
Are you referring to R14, (circa 1998) or 2014?
and what are you using to 'mask'  text -- wipeouts, background text masking for mtext? or ??
Message 9 of 11
Civil 3D 2014  /  Civil 3D 2017
mtext background mask
Video Card: Nvidia Quadro K620
Driver Version: 22.21.13.8601
Virtual Device: DirectX 11
Hardware Acceleration: ON
Smooth Line Display: Checked
Uncompressed Textures: Checked
"All Others" Unchecked
Message 10 of 11
pendean
Community Legend
Community Legend
You really need to be posting in the C3D forum since that software is pretty much unique compared to all other AutoCAD variants https://forums.autodesk.com/t5/autocad-civil-3d-forum/bd-p/66
And post a sample DWG file over there with the problem.
Message 11 of 11
WarrenGeissler
How were you masking the text previously? I just masked text with the Expresstool "Textmask" and it shows objects as you move the text. But if you use the textmask option inside the MTEXT editor, it will hide the objects as you move the text.
Warren Geissler
