As first:
Take a look how much work (=time) i spend for you,
note that i am abolutely the opposite of an beginner or a average user of this software.
So please, take time to read the whole answer, test things if you like,
post a sample if you mean you can recreate a test that shows that my answer is not true.
My time, only for you, please handle with respect - IO know how the program works
and it works in the same way everywhere.
>"Does this make sense so far?"
No, because if you using object snaps, it is not important where the cursor is!
My cursor is 0,24 miles away from the end point of a 1 mile long line,
the result of clicking (while acad uses the snap point) is exactly the same as your cursor stays exactly on the snappoint.
>"even more if I make the mistake and don't grab the correct osnap."
The snap mode (end,mid.. ) you can see by the snap marker shape (and tooltip),
And note: The possibility to snap to the wrong object is bigger on snappoints - where often are multiple objects.
Use a cursorposition on your objects far away from other objects.
>"How would this be a benefit,
because I wouldn't have to spend more time reaching the correct point,"
Thats absolut the opposite of the real live, it's more time consuming because
th cursor jumps (useless) between snap points. It is easier to navigate precisely if the magnet doesn't catch that much / early.
>"my cursor would already have snapped to the correct point because of the magnet."
That's not correct, th cursor would jumpo everytime when he detext a snappoint on an object
and the magnet can net read your thoughts.
>"I don't execute the command when I see the osnap, I execute the command when I know the magnet has grabbed the cursor,"
It' like Vodoo, absolutly useless 😉
>"this way I know I am 100% sure that I have the correct location."
NO, thats abolutly wrong! Trust me!
The only thing what important is, is the snap detection (that you can see by the appearing marker and tooltip, per default setting.
Important notes:
Check your OSNAPCOORD setting,
is it set to 2(defualt), or better to 1? That's ok. Otherwise (0) your Acad will not use objectsnaps.
>"When I say "snap point" I do NOT mean the invisible grid points..."
>"Snap = the invisible grid points in the background of the drawing that you can adjust the distance between"
>"Grid = the visible grid points in the background of the drawing that you can adjust the distance between"
>"Osnap = ENDpoint, MIDpoint, INTersection, etc."
YES, but in the whole thread we are talking about "object snapping", so for me it is okay to say snap osnap object snap
- in this thread we mean all the time 'Object snaps'
>"When I say "snap point" I mean the point in time when you are within range of the magnet and the magnet grabs the cursor and places it exactly onto the osnap location."
Is this better?
That's okay as explaination, but not correct.
My attempt at a common language:
snap point = the snapped point of an object (the position where the snap marker appears if enabled)
cursor position = the position of the cursor
cursor position while clicking = the position of the cursor in the moment you confirm the selection
>"From what I can see, APERTURE increases the search radius to find the magnet/osnap,"
not magnet, only for the osnap search.
>"such that it shows you the osnap marker as soon as it comes into range of the aperture radius/area,"
Yes, but it isn't "only the marker".
When you see the marker and you confirm your choice (left clicking), then AutoCAD take the detected osnap coordinates.
Where your cursorposition is, is absolutely irrelevant, irrelevant, uninteresting - as long as the marker is displayed, this determined position is used.
>" (but it does NOT increase the magnet distance,"
Right
>" you still have to move your cursor the same distance close to the magnet before the magnet grabs it."
Right, but it is useless to move the cursor to this point.
>"What I want is for the magnet to grab the cursor when it is farther away from the osnap marker."
We understand what you want and as we wrote:
1. There is no setting for this
2. It is useless and has nothing to do with the precision of the snapped point.
? Sebastian
